Beovision 14 issues
andersenpost wrote:
I got the update on saturday - it took app. 30 minutes, so it must be a heavy update.. only thing I noticed was the bootup time of the TV is faster now.
Are you sure it is a recent update? What is the update information that is mentioned in the update menu of your TV?
Hi
just checked - and NO - the software release date was in june😭
So i guess my TV "lost" its software and then updated it was the latest
Still waiting for a newer software version to fix issues - especially with the menus
Just got home from work and turned on my 14 and there is a software update available.
I am currently downloading it. I will check after I’ve done the school run and report back the version number
Version No. QM153E.0.6.3.9
realease date 03/11/17  12:43
took about 25mins to download and install
Interesting... nothing new on my BV14...
Still no update here, do you experience any improvements in the new software?
Not noticed any improvements, but I have just had a brand new set installed free of charge. May have sent through early as I asked the sales director to send it.
still have ghosting evident around people on some broadcasts but much better than the old set. Is has anyone else experienced this?
Im watching through a Sky Q 2TB box
blurring on my Horizon 48” is still noticeable but way less than it originally was.I assume that the panels on the BV14/Horizon will never be 100% free of blurring but hope they can fix it to 99%.
Do you have full multiroom capability with the new app?
The common release keeps getting postponed. I guess there are still issues to be solved in the update.
I just received an update of the B&O app for IOS (release 1.3). According to the text the app should work for the Beovison Horizon, Beovision 14 and Beovision Avant NG as from today.
