ThatGuyFromDenmark wrote:
Got the general release two days ago, but haven't spent much time with it (surprising considering how desperate I was to get it!), but my limited usage seems to be improved.
Though the first thing I saw when it turned on after the update was "Google Play Services has stopped" or something :) No problems since, and Multiroom seems to be working though I have to figure out how to do it the best way - connect the speakers to the TV or the Moment?
I am on the .115 release and still not too happy with multiroom yet. The Moment uses the speakers connected with the Horizon and that is not 100%. When I start playing music from the Moment, the TV has problems starting up. Sometimes it does start, sometimes not and have to unplug power of TV to get is rebooted again.
Also there is still no possibility to adress a speaker group to the Moment from the TV menu.
Only way is to make a myButton on the remote.
When I use the MyButton first to start up the TV and te Moment, it works well but then the sound problem (no subwoofer) as Karel described occurs.
This will be fixed in the .116 software, as said by Karel. Hopefully the Multiroom function is also improved in that version.
