Oh dear. When you did the last (week 10) update did the remote update too like it did for the week 5 upgrade? Mine didn't and has not since.
Beovision 14 issues
My BV14 sometimes comes totally blocked, no respond at all. Unplugged and works again.
Maybe it has something with mulitiroom function!?
Anyone else has this NEW problem??
No bricking at this point...
Karel.
Netflix is not supported.....yes i know some of us have it working occasionally, but from all that i am told, it should not work, and isnt supported, so dont expect any fix to it.....
And yes, i also have the second issue in your list....only returns to tv mode from set up by selecting TV from menu, or one of the my buttons if you have it set to that input.....
Did you not receive a Nvidea Shield to provide Netflix @4K? I thought everyone who bought the BV14 received one?
I haven't yet downloaded the update as yet. I'm wondering whether it is worthwhile. Should I wait or just go for it and hope for the best? What is everyone's thoughts?
