I have recently purchased and installed a new BeoVision 14 and frankly I'm not impressed. This could be because I need help setting it up but it may also be due to the fact that it is a disappointing product!
I'll outline my main problems below and would ask if anyone can point me in the right direction or maybe advise me on my chances of getting a full refund from B&O.
My main problem is with the quality of picture, not the sharpness but the contrast, no matter how much I play with the myriad of settings I cannot get a good evenly balanced picture. The dark areas always seem to be too dark and lacking in detail which results in the lighter areas of the picture having far too much 'pop' which results in a strange overly contrasty picture which is difficult to look at for any period of time.
I have also noted a slight lagginess when viewing normal TV via Freeview.
The other problem I have is that the text on the guide is so faint and small that you can't easily read it..... Not to mention the fact that when you are trying to adjust the picture you can't see the picture at the same time so every time you make an adjustment you have to go back out of settings to look at the picture again.
I have the latest firmware installed and I'm currently trying to book the engineer who installed it to return and help me out.
Am I doing something wrong or is this a problem others have experienced?
