Interesting (though sad).
could you tell us a bit more about how you use the M5 this way?
Sure the sources of the M5 are now visible in the BV14 and can be started with the remote.
But what happens with the M5, when you use it this way - it probably (?) remains silent?
Which means, that you can’t use it on its own, or???
And what happens when you tap/double tap it - does that start the BV14 from standby?
And can you control the volume (of the BV) from there.....?
