BeoVision 14 and Multiroom - Sound Drops
Interesting (though sad).
could you tell us a bit more about how you use the M5 this way?
Sure the sources of the M5 are now visible in the BV14 and can be started with the remote.
But what happens with the M5, when you use it this way - it probably (?) remains silent?
Which means, that you can’t use it on its own, or???
And what happens when you tap/double tap it - does that start the BV14 from standby?
And can you control the volume (of the BV) from there.....?
of course..!
In the integration menue of the BV14 it is possible to assign all mulitroom speakers of the network as the integrated device. In my case I selected the M5.
The M5 is still independent and can be startet without effect on the TV.
When I start the music with the remote one the M5 and the BV14 are both starting and music is playing on my selected speaker groups of the BV14 and on the M5. The M5 is the master and the BV14 is following automatically over multiroom.
Over the app it is still possible to control the volume of each device.
Wolf_70 wrote:
I would like to give a (pre)final feedback.
After many try and error investigations I come to the conclusion that at least in my case the combination BV14 and Core is not running stable. My final solution is that I have now integrated a M5 in the BV14 and now everything works fine!?
As far as I know this is because the M5 (and maybe the others on the same platform) is the only Multiroom product that has had a software update to fix the Multiroom for NL-televisions in combination with Airplay 2. M3 and Core are in the newest platform, and no fix available yet.
Wolf_70 wrote:
of course..!
Then your M5 seems to be ‘connected to’ the BV14, not ‘integrated with’ it.
This setting is made for the device in the app.
As seen here, my Essence is ‘connected to’ - but not ‘integrated with’ my Avant (and the V1).
Is that so with your M5, too?
You’re right, MM!
But I have made the settings in the BV14; not in the app. Interesting is, that it is not shown in the app (settings of the M5). This is although different to the Core. Settings from the integration menus of the TV were although shown in the app!?
There is a multi room hotfix available for the Core. This week I had my local dealer “push” the update to my Core based on the serial number. After this update I have had no more drop outs.
Best regards
Dyssegaard
Wolf_70 wrote:
You’re right, MM!
You will have to do both.
I was wondering, whether the M5 can be integrated at all = if the sound systems with built in speakers can integrate at all?
And I became curious, because you wrote ‘integrate’.
Well - I’ll have to do that test myself some day, when I have an M5 or M3 or......
The hotfix unfortunately did not help in my case.
Sorry to hear that.
My Core is integrated with a BV11 og yours with a BV14. That could explain the different outcomes of the hotfix ...
Best regards
Dyssegaard
Yes agree, it seems to be a BV14 topic!
