Beovision 12-65, any inputs?
You could also take a look at the Beosystem 4, you will have the same one remote control over your system, but you can keep your pioneer or get another screen.
wondering whether there is a way to calibrate the surround sound system with it.I'm pretty much set to buy the TV soon, but I'd like some form of sound calibration...Thanksi have bovision 12 65 ng with beolab 18 and 19 and brd player panasonic bbt01. excelent tv, superb picture. Beovision 11 55, Beoplay V1 40, Beosound 5 Encore, Beolab 9, Beoplay A8
Don't know if that is what you are looking for,
but you can find some interesting stuff about the BSys4 'sound engine'
Yes. That's pretty much what I was looking for. Thank you!Do you think this system can power on/off the beolab 5?Don't know if that is what you are looking for, but you can find some interesting stuff about the BSys4 'sound engine' here MM There is a tv - and there is a BV.
If you mean: put into Standby and wake it up - definitely YES.
if you mean: completely power off - no, because that is not intended.
You assumed right, I meant standby indeed. Thanks. Love the "YES"If you mean: put into Standby and wake it up - definitely YES. if you mean: completely power off - no, because that is not intended. MM There is a tv - and there is a BV.
