symmes wrote:
Electrified If you had read my post in context (or at all), you might have noticed that I was responding to the concern that Playmaker and ATV offer somewhat different file support. Any player can play a WAV file. With Max, you can rip to multiple file types to multiple locations. So there is plenty of reason for those who want to do something correctly, one time, to consider the process I use....or not. But for you to say there is no reason is, in fact, inaccurate.
I did read your post, and my point still stands: If you run Apple gear, you rip to ALAC, and if you run windows (or linux, for that matter), you rip to FLAC or WMA Lossless. Instead of using wav or aiff, where you have no support for cover art and the like, and in order for that to happen, have your library in a lossy format, the best option is to use lossless for everything. That way you can actually listen to lossless files and have cover art.
If my explanation didn't get through (which it evidently didn't), if you down the line feel like using Apple (or moving away from Apple), you can convert the FLAC files to ALAC - losslessly - removing the need to have a "back up" in wav or aif. In fact, if you then need a wav file to use in, say, a movie you're editing, you can convert that file to wav, again absolutely lossless.
As for your comment about "doing something correctly". I'm sorry, but since nothing is lost by having it in a lossless format, but much is gained, your "correct" way is not only cumbersome, but time consuming when importing anew into something else, and you will be using lossy formats. So, in order to get that, you have to import (convert) the song, and then download covers and what have you. Whereas if you rip to a lossless format, your backup will have that after the first time you did it.
Your suggestion of having a backup entirely consisting of wav files, and then have a library of lossy files to actually listen to, is naive at best. Why not listen to the lossless files, when it has metadata support far beyond WAVs and AIFs, including cover art?
