Beovision 11 recording
Owning Beovision 11 (55) I''m thinking about upgrading/enabling recording function.
What component should I be searching for and is it easily upgradeable without B&O technician ?
thx
m
thx
m
I have the recording function in my BV11-46.
To my knowledge it is a specific HDD with some B&O configuration so you cannot plug in any HDD without the help of B&O.
You can not ‘upgrade’ the BV11!
There are those, who say, that ‘anything is possible’.
However - apart from the difficulties in providing the needed parts - I dare not think at the cost ;-(
Aha - wasn't Aware of that
So it's either HDD/recording equipped from factory or bad luck ?
‘.....or bad luck’....if you say so.
What you could do, is to get an external tuner with recording function, and use that for recordings-only.
With a BV11 you easily can have that PUC’ed in order to use the Beo-remote with it.
Not the best solution - but maybe the second best ;-)
It would be a cheaper(probably the only option) option to sell the current BV11, and find one with the HDD feature, a new or used dealer would probably help out as a TV with HDD doesn't improve value that much, some stores still have stock of 11-55
