Beovision 11 Questions
I have seen a couple of postings with questions in regards to the BV11.
As the B&O manual by far doesn't cover everything, here's a thread to cover questions - and I start with my own first:
When I mount a USB stick formatted as FAT I can see the files just fine and play them, too. But as FAT there is no way to play huge movie files (e.g. Bluray files) - so I tried NTFS...
But as NTFS the Homemedia entry in the TV menu shows "No Name" for the USB stick and 'empty' ... no files are being shown.
Has anybody else found this or even a solution to this?
Try to format the USB stick as FAT32, not FAT...
Sorry, I meant FAT32 - but that does not handy files larger than 4GB, thats my problem
I believe most NAS's use EXT3 format and they can handle large files and talk to DNLA devices such as BV11. Try it out. And let us know if it does the job.
How is the BV11 in terms of noise from cooling fans? The fans on my BV10 become quite loud (and annoying) after an hours use or so.
sorry, cannot format a USB stick as EXT3 on my mac - but thanks for the suggestion
Has any BV11 owner tried the Homemedia via USB?
In terms of cooling fans: I have not heard any fan a single time so far ... and I did use the set quite intensively over the last days 😁
when I first saw that reply I checked on the EXT extension - it is Linux based
but there is an extension called FUSE that you can install on OSX to get you that capability
About fan noise.
I hope that no one have discovered any, as there are no fans inside a BV11 🙂
The only noise that someone might hear is coming from the HDD.
We plugged a clients external USB drive in to his BVIS 11 and drive name was recognised as he had named it and it played the AVI files. I have a Mac mini in the showroom and the movie files stored on the Max play through Plex media server using the Homemedia source. Why aren't you using Apple TV to draw the video content via the mac, this is seamless and it has a better interface?
Just to clarify:
NAS = Network attached storage
-> Basically a large harddisk that can be accessed via the network
CAN include a MEDIA SERVER that MIGHT BE based on DNLA
-> a programm running on a PC or NAS that offers files to other systems (TVs etc.)
A USB stick (or external USB disk) should always be formatted NFTS (windows user, sorry) to support large fils
(sure not if USB stick is 4 GB or less).
NFTS is not recognized by all TV, though.
SO, I'd follow the advice and use a hidden box that communicates with a NAS (NOT a media server though, due to performance issues, tagging of files).
I use a Western Digital Live TV HD that accesses my files on a Synology NAS (had a Buffalo Terastation NAS as well, that was good, too).
The WD Live has a USB port, too...
Best regards
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
