BeoVision 11 drops HMDI signal for few seconds
My BeoVision 11-46 drops the HDMI signal intermittently for 2 to 3 seconds (ie. sound and picture disappears) then resumes as before.  This happens 2 to 5 times over 3 hours viewing period.  The TV operates normally the rest of the time and all the time when taking a signal from an aerial connection.  I have connected the HDMI cable to another TV (Samsung) and it works perfectly – so the problem is at the B&O TV and not in the cabling etc..   I have tried HDMI sockets 1,2,5 and 6 with the same result.  The TV says the software is up-to-date.
My video signals (SKY, DVD, Apple TV) come into a Ubiquiti Networks switch and an HDanywhere control box (everything is controlled by Control4) and then by HDMI cable to the B&O TV.
 Any suggestions?
I would still get a new HDMI cable. It´s a bit strange that its the same problem with all the HDMI sockets.
This happens with my work monitor all the time.
Just 2-3 seconds and it’s back
I reckon it’s a cable which this monitor somehow doesn’t like. I should change it.
I also had problems with my Apple TV and then swapped the HDMI cable. Since then it runs trouble-free.
