I may be in the market for a used BV11-55 and have some questions to which I can't quickly find an answer.
There are (limited) smart tv functions on the BV11, does anybody know if it is possible to have a plex app or kodi app on the tv? Or am I forced to connect a mac-mini and control it through PUC?
Is the music player any good? Can it read a shared itunes library and can it be controlled using an iphone app without the need for switching on the BV manually with the beo4? Is it responsive, or slow as hell?
What I really want is to play my own music (no deezer or spotify, but an itunes library (which I could put in a DLNA server if necessary)) through the connected speakers, preferably without the need for the screen to be on. It would be great if my beolit12 could join in seamlessly (which it does now, see below).
Second, I want to watch movies and series (mkv files, some lossless, others compressed), be able to download missing subtitles, using only one remote.
I'm currently using kodi on an old macbook connected to an LG screen. I have to manually switch on my tv, the sound receiver/amp, and to use my mac remote for controlling kodi. Apart from this, it really works pretty good. My macbook is never switched off, I can remote-control itunes from my iphone and it plays simultaneously on my beolit12 and through the surround system in the living room. Ideal to put the beolit on the terrace, or in the kitchen and have multiroom functionality. It just works, when I'm working in the office upstairs, I can take the beolit, use the iphone to press play on the itunes of my macbook, and the beolit simply takes up the sound, without the need for the speakers downstairs to be switched on.
I'm afraid the beolit will not be able to join the beovision's sound, but I could live with a hidden, always on, mac mini hosting my itunes library. In that case, Is it possible to program a button on the beo4 which would switch on the BV in audio mode (picture mute) using the same hdmi source as would be used for watching the kodi application? While having another button to switch on the BV in movie mode for watching kodi?
Thanks for your input!
