Beovision 11 46" - Apple TV 4
Hi
Anyone with a BV11 46" bought the Apple TV 4?
- I would like to know if it fits behind the panel on the back like the ATV 2/3.
This has already been discussed if you search the forum for it.
Apparently (from memory of the thread) you can remove the back of the ATV and it then fits.
Dave.
Thanks Dave!
Is the back easy to remove?
Hello again found the thread:
WOW! I received mine yesterday evening. I can confirm it fits INSIDE the BV11-55 without to many issues. You just have to take off the bottom panel, which is quite easy and only a few minutes work. See iFixit.com for instructions. With the bottom panel installed, it is just a few millimeters too thick. With the bottom removed, it just snaps into place and the BV can be closed without putting any force on the back panel.
I don't consider it an issue the Apple TV now has no bottom panel, maybe it is even better for cooling, I don't know. The PUC works great, and also the BlueTooth Apple remote works fine with the ATV inside the BV.
I haven't tried the ATV itself yet, but so far, I am very happy and still have no cables and boxes lying around except for the TV itself.
BeoVision 11-55, BeoLab 8000, Beo6, AppleTV, BeoPlay A2
- But that is for a 55" BV11
So once more....
Why don't you just measure the recess size in the TV and check against the ATV4 dimensions?
Dave.
To answer your question...
It would not give me the answer since I don't know the dimensions of the ATV 4 when to bottom lid i striped of!
Why don't you just stop cometing in this thread, if you don't have an answer to my question? 😡
I'm trying to be helpful and give you an alternative to finding out.  Nobody has answered your question which implies that nobody knows yet as the ATV4 is so new.  I could have measured that in 30 seconds for you if you'd have asked nicely.
You could at least be polite on this forum and try to appreciate that someone is trying to help you or offer alternative suggestions.This will be the last post I ever make to any of your posts whether I know the answer or not.
Goodnight.
Dave.
Dave Farr wrote:
Good statement, Dave!
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
That's not an approach, that will give you many friends (and helpers) on this forum.
If you only knew, how much time Dave spends on the forum just to help and answer questions, I am sure you wouldn't have shoot yourself in the foot.
