Thanks for info, unfortunately I have a plasterboard wall, on outside of the bracket I can luck I can hit the studs they seem to fit the bracket perfectly they are Cutter Pozi Screw 6.0 x 70mm. Once I have installed the BVIS
Beovision 11-46 wall mounting
Hi Graham
I have now managed to mount the bv11-46 on the wall bracket. I have two questions is it easy enough recover the fret on the speaker? The other question is the bracket. I can move the wall bracket to different positions manually but I don’t see any lead to plug it into the socket marked stand on the tv?
Did you resolve this? You need the separate hinge motor that plugs direct to the TV after locating it in position.
As far as the fret cover is concerned I would remove the fret from the TV and then paint it with fabric dye. You will never get a good fit by applying new fabric in my opinion.
Graham
Graham
