i was luck enough to be given an 11-46 with the hinged wall mount. Are there any instructions on how this is mounted. I can’t see anything online. I can see the plate attaches to the wall but not to sure how to attach the tv. On the right hand side of the beovision, I can see the parts that swivel, do these locate onto the plate on the wall and screw in?
Beovision 11-46 wall mounting
Hi
The only source I can find online is
Hi Mm
That is really appreciated. It does not look easy but I will have a look tomorrow and see if figure this out Tusand takHi Millemissen
i have looked at the bracket, it looks like I’m missing the screws for the the bracket that attaches to the tv, there are 7 small countersink screws that attach to this the hinges. I have attached a picture just not sure what the size is ?
Could you maybe describe what you actually have!
Maybe someone else can chime in ?
It is a long time since I dealt with that - do not remember exactly.
I’d have to stand in front of one to recall it.
However this is what it looks like, when installed:
Login to view image
Login to view image
Hi
i have the two parts of the bracket A and B and I also have the countersink screws for all hinges that allow the bracket to mounted to the tv as well as the wall bracket the only parts I appear to be missing are the small countersink screws they are called 7 X DB othe only one I’m missing is 1 x DA according to the manual you kindly linked to
Best consult an installer.
They might have installed one of these recently - maybe they have the spare parts.
Hi Millemissen
I will ask them and see if they can advice will post back and let you know thanks for all your help
From archive… my BV11 40 hinge.
/forum/general-discussion-and-questions/beovision-11-on-motorised-hinge
Graham
Graham
