Beovision 11-40 transportation
Hi all, In a few months, I will be moving from Germany to France, and I would like some advice from you on moving my Beovision 11-40 with the motorized floor stand. Essentially, I have two questions:
  • Do you recommend unmounting the floor stand when moving the TV?
  • If I replace the floor stand by the easel stand, do you think it will be easier to move? Do you know if the easel stand is foldable?
  Thanks,
Definitely unmount the tv from the stand, when you move it.
I would also do that, even if I just had to move it around inside the house.
The easel stand is very heavy - you can not move it much when mounted.
It is not foldable.
Thanks a lot for your answer!
Do you know the "easiest" way to unmount the floor stand? I saw there are 4 screws behind the tv, I guess we just have to unscrew them.
But how do you hold the tv while you unscrew the stand?
Thanks again
These 4 screws are not ‘holding’ the tv. They are there to secure the tv, when it hangs in the right place/position on the floor stand.
Unscrew and lift the tv upwards with the bottom slightly tilted to the front.
You should never do this alone - it is a 2 person job…..unless you are experienced and/or a very strong person.
My advice would be to have a couple of boxes or alike to place the tv on after lifting it off….let it lean against a wall. This way it will be easier to grab it afterwards, when you want to carry it to the new place. Alternatively put it on a bed, a big sofa or alike…..the screen up!
The tv is heavy!
The stand can be carried by one person - take care when you pick it up.
Ok understood, I will try this.
Thank you very much for your advices!
Hi all,
I just wanted to thank all of you for your help, the unmounting went very well (as you can see on the picture)
Thanks,
Attachments (1)
