BeoVision 11 - How to turn off auto Sound Mode selection
Hi Guys,
A quick question. How do you turn off the auto sound modes as it keeps going into Music mode and I have to manually select Movie Mode on the sound option. The adaptive mode is greyed out. I have the Beo 4 remote.
Thanks TC
When you go to sources you can specify sound modes it should use as a default.
Thanks, I do that, but it keeps changing, I cant see a default setting?
Many thanks, I give that a go later and let you know how I get on.🙂
Many thanks for the clear precise instructions, worked a treat! 😁
