Very nice installation I must say. What type of wallbracket are you using? Not B&O I assume since you are able to swing the set out that far. Can you take a pic from the backside of the BV10?
Wow, that is a fantastic looking set-up Martin 🙂
Wow!!
Wonderful installation in a beautiful living room. Congratulation. I suppose the bracket is by STB, isn't?
It was an issue with the early models, since then the cloth type has been changed so there are no problems now.
Correct. What shocks me though is that my (and other) dealer has two old white frets on display and you can clearly see the magnets underneath. This would never have happened in an Apple store (as an example). Presentation is everything. I mentioned it to my dealer, but can you imagine the number of people who may have thought "you can see dirty marks under the speaker fret!" and not mentioned anything?
Why didn't B&O issue a writ to dealers informing them that they must remove the old fret?
Remember the silver Avant speaker fret?? You could clearly see the speakers behind it, this was never resolved to my knowledge!
Jonnie
Thanks for the compliments! It is on a motorised wall bracket available from link, installed by Bang & Olufsen of Newcastle, UK.
Here is a pic of the rear as requested.
Wow.. This is the bracket I wanted for my bv10 as well. Would it be possibile for you to upload of video showing the motorized movement?
Well, lets see now!! Just ordered a replacement fret under warranty. Hopefully rectifiefd the issue??
Jonnie
Fingers crossed! I want to order the white fret, so let us know how you get on JC.
Yes of course!!
It is not just the white fret that is changeable under warranty but all colours!
Jonnie
