BeoVision 10 white speaker cover
I'm thinking of a BeoVision 10 in white but I saw that the cover looks dirty (round spots on the cover).
I noticed it in several shops. Is it something that appears with the time and can it be avoided?
I wouldn't like to buy an expensive TV if it looks that dirty after some months.
Thanks.
link
link
Usually shops are located near quite a lot of traffic, and I noticed the very same with a BV10 in a Shopping Gallery here. The televisions in the shop (located deeper within the shopping gallery) did not have this problem, but the ones on display near the entrance had it.
It seems the magnets that hold the front-cloth in place are "traffic dust magnets", i.e. collect traffic pollution over time.
This shouldn't be a problem in an home environment, unless you keep windows open all the time and live in an area of heavy traffic. Plus regular cleaning with a vacuum cleaner, set to low power, will help keep the white cloth white.
Thanks for the reply and the advise.
I have a brand new one in white. The spots are present even from new, may get worse with time not sure. Pretty poor really, this should have been dealt with at production!!
Jonnie
This sounds quite strange to me. I will ask more information to my dealer the next time I will see him. I have a black one, but I planned to purchase a white one as well...
thats dust isn't it?
I don't think that you have chance to avoid it after a certain time!
Regards Elmar
No it is actually the magnets that show through the fabric😮
no, it can't be that they let it pass the quality tests and didn't notice anything...
Is this the same problem with all light colors?
Yes i noticed this with the white ones showing the magnets! My B&O dealer had one in the window and it was very very noticeable.  White magnets needed?
