Hi all, I was given a Beovison 10 which has been in storage for a while, so I connected some lab 6000s, chromecast etc. etc. and then turned it all on. The tv stations play fine, but I don't have access to the Sound or Connections menu (they simply don't appear). I reset it a couple of times, but the initial setup does nothing beyond tuning the stations.
Is there a simple explanation for this? is the input board fried? and if so, can it be replaced?
I hope somebody can help, as it's very pretty, and an upgrade from the BV5 currently in the room ha
