OK.
I hope a stand program will be proposed like a floor stand for instance (the report said "an elegant floor stand" if i remember).
I fear it will only be presented first with the wall bracket... 🙁
OK.
I don't believe they can release it without floor stand, that would be a really, really bad strategy : a vast majority of people don't want or can't (physically or legally) place a screen on their wall.
As they have announced the "elegant" floor stand at the same time, I don't understand why you are fearing that. Maybe the wall mount will be embedded in the TV concept, and the floor stand will be an optionnal base where you fix the wall mount.
I dream of a motorised floor stand ! 😳
But as you said, it's not in the same league as the BV7, more like the BV8...
Who knows...
I understood that the stand will be motorised (and also said to B&O that making a motorised stand for the BV8 would not kill any of their upper TV sales, and allow them to make more margin with BV8 addons/accessories... Let's hope that this idea goes up enough in Struer...)
slim design + AR screen + amazing sound + motorised stand = a true B&O product 😳
In the UK approx £6500 on motorised stand - about £300 less wall mounted. I've seen it and it's beautiful...
Wow !
Seems promising !
I hope they will soon show us a teaser picture !
As a big fan of the electronic curtain 😕, do you think the BV10 will get it (i hope because the BV8-40 has it) ?
That's impossible that the BV10 doesn't have it : it is a very well perceived line of code in the software! It cost nothing but adds great perception of the TVs...
What should be improved is the startup time of the DVB HD module : when switched on, the curtains open to a timer image for some seconds, and not to the TV image... That's very cheap looking, and occurs with the BV8 and BV7.
Hi all,
I visited my dealer yesterday, The BV10-40 will have the LCD LED panel with 200Hz. I was also told the shape is more square than rectangle, with an sensor eye not on top but lower placed in the frame or speaker. Also the whole front is GLASS all the way down with holes in it for the speaker sound. I also had a brief look on the BV10 manual from a distance, sorry I have no more details.
The sound was described as for more better and impressive than BV8-40. My dealer told me this info after he visited the LIVE introduction for dealers only.
Regards, Robert
