Beovision 10 clock
Hi folks.
I have a BL3500 attached via masterlink to my BV10. The link speaker is showing the wrong time and numpty here is trying to work out how to adjust the time on it.... I am guessing that it takes the time from its 'source' device and that I need to adjust the time on the TV. Can anyone explain how I do this please? I have looked at the TV user manual but have drawn a blank.
Thanks!
C
Any advice would massively appreciated!
C
Hi C,
the BL 3500 receives the time from the main system, but only if the main system has an integrated clock. Because the BV 10 has NO clock, you can´t display the correct time on your BL 3500 (and you can´t use a play timer). So you have to set the display of your BL 3500 to NO CLOCK.
Regards
Räuber
Hi Rauber
Thank you, that's very helpful indeed. Mystery solved!
All the best
C
