just done. Thanks!
Beovision 10 Black high gloss Polished aluminium
Very cool !
Hiort, i think to add a BL11 to my stand alone BV10-40.
I search for a more punchy sound with "well-controlled" bass (don't want a boomy effect) for blu-ray music live for instance.
Does it do the job ?
It certainly does exactly that. You can adjust the bass from the BV speakers as well as for the BL11 individually, so that it suits your taste. As I mentioned, Iยดm very happy with my setup.
You can see pics here : /forum/general-discussion-and-questions/flash-your-bampo
You are convincing me but before purchasing the BL11, I would like to listen to the BL12-3.
Here's a very rough-and-ready iPhone photo of my newly installed BV10-46. Ignore the image, it was a concert in HD that was on when taking the shot:
Wow!! I like it!
Had I had somewhere to place it, I would have gone for the same stand. It's gorgeous!๐
Wow!! I like it!
Yep, I had reservations at first. Looks really low. But when you're on the sofa, it's the perfection position.
Only snag is, the easel stand leaves the BV10 on an angle which I'm not used to. It's going to take some time to get used to that!
Got a black and orange grill, plus an orange grill for the BS8!
Hey moxxey, i'm liking your new tv looks beautiful. How you finding the picture quality in comparison to the bv7 you had?
moxxey, would you mind taking a picture of the back of it, when you have time, and post it?
Thanks.
Paolo
Some feedback on the BV10-46 after owning a BV7-40 for the last four years.
Picture is *better* than my BV7-40 MKIV. So much for the "Beosystem 3 improves the image" theory most people like to throw around (probably to justify the cost of the BS3). I guess the panel is newer and it's a 200Hz panel, which helps when watching sport in HD. Definitely a step up from the BV7-40 though.
Sound is reasonable. Not as bad as some people have made out. It's no way near the level of my outgoing 7.2, but it's more rounded than a top-of-the-range Samsung! But it is lacking for B&O speakers.
Love the red grill and the BV10 design. Easel stand makes it look really classy. Just got to get used to the angle!
very very nice moxxey !
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
