RWST wrote:
Hi KMA,
Any response yet from B&O regarding"your" case?
Thanks in advance.
Hi RWST,
Unfortunately no, B&O Customer Service have given no response to the complaint I sent them about the backlight clouding defect. It seems that no brand - no matter how high-end - wants to touch the subject even with the longest of sticks. This seems to be the industry policy.
However, I noticed the BV10 Service Manual is now online for BeoWorld Members - thank you admins! - and had a look at what it says about replacing the panel.
It seems to be quite a simple procedure, with only a couple of steps involved, and the service can and should be done at the client's home. That is good news.
However, I am still hesitant to go down the service road, until B&O indicates that they have sorted out the backlight quality issues completely, for a couple of reasons:
1) From the Service Manual, as I also suspected myself:
General considerations
- Correct adjustment of all parameters can only be obtained by using special test signals and equipment for light measurement.
=> This refers to the special calibration equipment and conditions used at the factory for individual calibration, or to an ISF certified professional calibrator with very expensive pro calibration equipment.
- Factory settings will give the best result.
=> Best general results, yes, but not the correct/optimum results, referring to the first consideration about calibration.
In other words this means that a serviced BeoVision 10 does not have the benefits of individual calibration at the factory, and the calibration to the optimal individual parameters is something we pay for in terms of B&O picture quality. The difference may not be much, but it's nonetheless a trade-off in picture quality with serviced panels.
2) With EdgeLED panels, which are generally more prone to backlight defects than conventional CCFL-panels due to their extremely thin structure and sensitive light-guide plate, there is no guarantee that the new panel would be better. There's a reason why Samsung, the panel manufacturer, uses automatic dimming in their edgeLED-TV's: when the image has dark content, the backlight dims radically, which hides most small backlight problems. This is mentioned in a few Samsung "LED-TV" reviews.
3) In addition, the replacement panels are shipped separately as single units from B&O or their supplier, and can easily be mishandled by the shipping company during transit. That is the reason why panels are usually shipped in large quantities from suppliers. The size of the shipment protects the individual units, and large shipments can only be handled the way they are meant to be handled. Transporting a single edgeLED-panel for example laying flat (and not in the correct upright position) is pretty much a guarantee for backlight problems caused by structural stress during transport.
This is one of the reasons why there are documented cases of serviced edgeLED panels being even worse than the original in terms of backlight uniformity. This is also the reason why BeoVision 10 is packaged the way it is, and why it is transported on a pallet, securely upright.
From the Service Manual again:
Transport and handling
The product must not be transported placed on the screen.
In short, it's a lottery how a serviced panel will turn out.
I can try and live with the current panel with its backlight defect, if I stick to watching BeoVision 10 always in a well-lit room. However, having pretty much all the lights on at night when watching TV somewhat ruins the home movie experience :)
I'll try to squeeze in a meet with my dealer this week, to see if they have any suggestions, and what is their opinion on the matter.
