I have recently had a BeoVision 10 46" television installed at home, upgrading from the Avant TV. However, it was a surprise to find out that the clock no longer displays on our BeoLab 3500 speakers around the house and they no longer turn off automatically. The supplier has informed me that the Avant used to have a clock inside it. However, the BeoVision 10 does not. Bang & Olufsen has apparently confirmed that there is nothing that can be done about this. The only option is to install an audio source on the system (which I do not have) that has a clock in it or keep the Avant on the system.
Has anyone else experienced this problem or found a solution? Is there a software/hardware update for the Beovision 10?
