Beovision 10 46 andblurred fast moving ball
Dear All,
I have just bought a new BV10 46 and think it is amazing. Great picture on HD channels and blu-ray...
However, I do have a slight problem with the fast moving ball in cricket - watching Australia vs England .......
The ball is blurred when sky are showing a side on view of the fast moving ball. I have read a few posts on here before and have found a paragraph printed below as to how to solve this issue. You have to change 'the game mode'.
For game mode; Menu-Options-Picture. Scroll down to "game mode" (at the bottom of the list on my TV). double click for on and a menu bar at the top of the screen briefly advises "game mode on". The mode only remains "active" for the channel you are on. It defaults to off again as soon as you change.
My problem however is that when I am watching Sky HD through the DYV channel when I press menu on the Beo4 remote I get the sky menu and not the menu for the TV. Des anyone know a way around this and how I can turn 'game mode on' from the Sky HD channel?
Thanks in advance and I hope this can de done.
Regards
Yeabo
The new Beo 4 that we bought with our BV 10 has "game" as one of the functions that can be added under "list". Maybe that would work.
what happens when you press [MENU] twice ?
menu menu does the trick
Thanks to everyone - menu menu does the trick and I have now added game to my list on the Beo4..
I did try this last night but still found the ball was slightly blurry, though better...
Does anyone have any other ideas on how the problem could be solved...
Thanks again to those that have helped.
Regards
Yeabo
could it be a typical lcd problem🤔
