BeoVision 10-40 Question regarding height
Does anyone out there know the height of the BV10-40 when it is mounted on its floor stand?
I've seen the images of the BV10-40 standing next to a pair of BL6000 speakers, but I'd like to know how it might look standing next to BL-8000s and a BS-9000 CD player. I fear it may look a little too short. If it is too short, will there be a taller or adjustable BV10 floor stand made available in the future (like the adjustable BS-9000 stands)?
Thanks in advance for any information!
Mike
I do not think they will make an adjustable or higher floorstand, and personally I think it would look at bit silly :).
Accroding to the catalogue the hight is 107 cm on floor stand, which is about the same hight as the BV7-32 on floor stand - try to find a picture of BV7-32 with BL8000 which might give you an idea on how it will look.
Christian
Thanks for the information!
It so happens that this is also the exact same height as my Avant.
