Hi. My Beovision 10 changes sources on it's own randomly. When I'm watching cable on v.mem, it changes to DVD without warning or without anyone even holding the beo4 remote. Has anyone experienced this? Could it be a setting?
thanks
John
thanks
John
Does this only happen to DVD mode?
Does this also happen when your Beo4 is "not in the room"?
Is the BV10 your videomaster?
Are there any link rooms, so you could test your remote in a link room?
Some members had similiar problems with BL1000 remote and , as far as I remember, some with Beo4 too.
Hope this helps
Stefan
Hi Stefan
I don't have any link equipment at all. Just the bv10 with a set top box and blu ray connected via hdmi. Only other thing connected is Beolab 14 home cinema.
I haven't tried it with the beo4 not in the room, but I have gone as far as changing to other beo4 remotes from other rooms just to see if it's the remote causing the problem.
Very strange.
