Beovision 10-32
Hi!
I am currently looking for a bedroom tv and am considering the BV10-32.
Does somebody know if there is any big updates coming soon specially regarding the LCD display? Maybe LED?
Also what cables should I use to connect to the rest of the system (BV7-40 and BM/BS 5)?
I am only intrested to get access to the BM5 music and play it on the tv speakers.
Is is best to use the Masterlink between the tv´s or can I use the ethernet CAT6 that I use in my network?
Brgs
Christer
Christer wrote:
Hi!
Brgs
Christer
You can use cat6 cabling if it's shielded , but it NOT ethernet so you cannot conect tv or other b&o to your router
but you can use your house cabling from point a to b so to say and with b&o cable RJ45-ML
