I've had BeoVision 10 46 inches in 6 months.
It is the worst television I've ever had.
I've had b/o for over 15 years but is now considering selling the whole thing and buy samsung or panasonic plasma, to get acceptable image quality.
We had BeoVision 10 - 46 for 20 days but the dealer had to change it to a new TV because the sound making a cracking sound both when we were watching television and heard music.
Since we bought it, it has also had the following errors
When we watch television at night in darkness and they are:
advertising with a black background
film on black background
DVD with scenes with black background
Source Change (TV to PC / DVD) screen is black
you can see 4-5 light columns (15 cm size) top of the screen divided into each corner and 2 in the middle. We sit in a normal angle and watch television and the light columns is not a normal change in brightness as you typically see on LCD / LED TV for instance if you change the viewing angle.
TV must be turned on for some hours to the fault can be seen
B/O have changed ledpanel 20 days ago to correct the errors above but now we have same problem again.
I've talked to a B/O distributor in Copenhagen and he looks surprised at me when I tell the story and says they have had 8 customers within the last month with the same problem and that in b/o know the problem and call it bleeding backlight !!!
In my view, a television of this quality / price could show a normal black level at the film / advertising etc. and therefore not acceptable that it does above.
Why has B / O made a decent test before they sell it ???
I've had beovison 4 to 50, BeoVision 7 - 40, BeoVision 6 -26 and has never had or seen this problem before.
Think B / O has a pretty big problem in this television and the above panel. What will hapend when the pres get this info ??
I'll try to call my purchase back because we can not live with so poor a panel and television.
