Hi.
Not been around for a long time...
I decided to try and clean the speaker grille on my Beovision 1 but I cant get it off at all.
Any tips please?
Hi.
Any tips please?
Dont panic!
I have managed to clean them without having to remove the grille.
They look good as new now.
If I remember correctly there is a small hole on top of the speaker where you need to stick something that fits in that will then release the front cover to be pulled up.
Edit: That idea above is good for BeoLab 1 - not BeoVision.
This is how you should do it.
