Beovision 1 operation with no remote control?
The original Beovision 1 (and Beocenter 1) were controlled by the Beo 1 remote. They then changed to Beo 4 later. The Beo 1 is a fabulous design but relied too much on the TV menu to work. If you aren't using the TV fully then the Beo 1 will probably do for you. They go for under £30 here in UK.
technov1king, I just re-read your post, if you have the built in DVD, then yours will be a Beocenter 1, and the Beo 1 will control the DVD.
Stoobie
Exeter,
Devon,
UK
Well i cant seem to find that remote here in the Netherlands. And i think 30 pound is a rather step amount regarding most of these tvs are free to pick up.
so, you can use the beovision without remote or no?
No
See here - he will post to NL:
You cannot control it without a remote. I have looked at my Beocenter 1 and you can only open and close the DVD. That turns the TV on but no other control possible. There are 2 buttons,  one physical button for the DVD tray and 1 physical button for power on/off. But the TV should remain on (in Standby) not off.
I also have just tried a One For All UR-7120 (universal remote) and that can control the TV but not the DVD.
Edit - the Beovision 1 will be the same. No control without a remote.
Also, if you do decide to take the TV, ensure you get the pin number (if it is activated) otherwise you will not be able to use the TV at all.
Stoobie
Exeter,
Devon,
UK
