- I have checked the documentation of the Bluetooth chipset I'm using, and it seems possible. I might look into that in the future.
- Hmm this one I haven't seen, but I mostly use my Beotooths with an Android phone or a Linux PC. I'll try to get my hands on a Window PC to check that !
- You're right about that. In my mind, the Beotooth is meant to be used at a fixed volume level, with the volume controlled by the Beomaster. I'll try that, and see if I can make changes to the scale.
