I have a Beomaster 2400. Would the Beotooth work with that? If so, I'd be interested in purchasing the kit.
Sorry, I can't find where to send a PM.
-Caleb
A little curious question. Would it be possible to change the TAPE command with the CD command for the Beotooth 5500? One usecase I could seen for this is a computer using one Beotooth as speaker connection, and the other beotooth could the be used for connecting a phoneThat is a good suggestion. Maybe a small swich can be integrated which chooses to which command the Beotooth will react: Tape, Tape 2, N.Music, CD ...
<p>Very interesting device and good work!</p> <p>Does it support other codes than AAC? For example aptx?</p><br> The Beotooth uses the Microchip BM83 Bluetooth module, which only support AAC and SBC. I ad a look at AptX in the beginning of that project, but it is a Qualcomm proprietary technology, only available on Qualcomm Bluetooth modules, and Qualcomm doesn't give their SDK to everybody except, so no luck there. AAC should deliver a similar quality to AptX (except on some phones where the AAC codec seems flawed, but that's an issue with the phone manufacturer).
<p>A little curious question. Would it be possible to change the TAPE command with the CD command for the Beotooth 5500?</p> <p>One usecase I could seen for this is a computer using one Beotooth as speaker connection, and the other beotooth could the be used for connecting a phone</p> <p> </p><br> That's an interesting idea, I had not thought about that (as I still listen to CDs on a regular basis). On the back of my mind, swapping the control messages should be fairly easy, the status messages are a bit different though, but nothing impossible. I'll have a look at that when I have some free time. (It could be added as a selection command through the USB Serial interface, that is already used to customise the Bluetooth name of the Beotooth). There would be only 2 options here : Beogram or Beocord emulation (AFAIK Beogram CD and Beogram uses the same command set). On a system with CD / PHONO / TAPE / TP2, CD and TAPE share one datalink bus, and PHONO and TP2 share another bus.
Hey, Sorry for the long delay answering, since the forum update I don’t get emails anymore when replies are added to the thread.You might have to re subscribe to the thread. Thats is the case for all threads I have subscribed to before the changes.
That’s an interesting idea, I had not thought about that (as I still listen to CDs on a regular basis). On the back of my mind, swapping the control messages should be fairly easy, the status messages are a bit different though, but nothing impossible. I’ll have a look at that when I have some free time. (It could be added as a selection command through the USB Serial interface, that is already used to customise the Bluetooth name of the Beotooth).<p style="text-align: left;">Great to know it is possible no immediet need for me, but some other usecase might show up</p>
There would be only 2 options here : Beogram or Beocord emulation (AFAIK Beogram CD and Beogram uses the same command set). On a system with CD / PHONO / TAPE / TP2, CD and TAPE share one datalink bus, and PHONO and TP2 share another bus.That was also my understanding. The current TAPE function works both on the Tape and the Tape2 connection on my BM4500
