Hi Does anybody know if a beotime clock will control a beosound 2 2017
thank you Gary
thank you Gary
No. The Beosound 2 does not have the IR receiver for the BeoTime.
But You can turn off all NL products with it. I've done it with mine.No. The Beosound 2 does not have the IR receiver for the BeoTime.
Hi Gary,
Unfortunately, Beotime can't control the new Beosound 1 or 2, as they don't have IR input sensors. However, Beotime can be set to switch on any older B&O audio or video product via infra-red remote control when the alarm comes on. There is also a "hidden" menu on Beotime to give you full control of your lighting when the alarm comes on, you can see full details here:-
Really? You don't have any ML products that pickup the IR signal and send it to NL devices over a BLC?But You can turn off all NL products with it. I've done it with mine.
No ML products. I can even change the channel with my AvantReally? You don't have any ML products that pickup the IR signal and send it to NL devices over a BLC?
Can you switch Beosound 2 off stand-alone with Beotime without connection to another NL-device, too?
I'll try when I'm back home and advise.Can you switch Beosound 2 off stand-alone with Beotime without connection to another NL-device, too?
Aha... the Avant takes IR and is also NL capable. That is why it works.No ML products. I can even change the channel with my Avant
