beotime - on time ?
Great work Beoworlders. Finally, something interesting from B&O.
does anyone know who designrd it?
Now I know whats on my Christamas wish list.πŸ˜•
CraigπŸ™‚
So is it battery power only or can it have mains power? Why not rechargeable battery with the stand as its charger???
I do like it and my dealer told me it is very attractively priced πŸ€’
Ignace wrote:
Chrisreunion wrote:
If I read correctly, you need to press the remote at least 5 times to turn on a source, and 6 times to turn it off??In that case, why is it more expensive than Beo4?😁
Using a controller, performing multiple actions to reach a certain item in the menu...
....., reminds me of the 1st version of BMWΒ΄s  iDrive !
πŸ™‚
Why are you smiling?? The 1st version of the iDrive was a disaster!
Another thing puzzles me: the left/right display change on such a design is quite useless, and just an "Iphone reminder": do people turn their Beo4 left or right? Neither, they use it vertically, which would have been so much more logical on this flute design, that could have stood up on your bedside table, like a Beo1. And take less space as well.πŸ€”
Good point. Vertical use should be easy to fit in this design. Not sure about the vertical position when it's not in use, though. My Beo4's are always in a horizontal position when not in use...
I have heard with a software update for 99$ you can use it horizontally. Then the displays are showing text horizontally.
TWG wrote:
Few more questions:
- does it display the  time constantly or only when you touch it?
- What kind of backlight does it use? I hope it is not as bad as in the "Beo4 cinema"!?
- will it have some kind of "low battery warning"? I think this would be necessary, as it is NOT funny when it didn't wake you up because of dead batteries ;-)
btw: I think it is a GOOD decision to use a monochrom LCD like on the Beo 4 as it requires very low power = good battery life!
Can anybody upload the usermanual / userguide of beotime?
I really like the alarm/remote, let's hope the price will be right and I will trade in my beo4.
I've sent the manual to Ignace, so I suppose he will make it available soon in the manual-download section of this forum.
I suppose it will be usefull to be able to change directions left/right, because it will allow you to choose between the left or the right side of the bed still using our right or left hand wichever you prefer, I for one will hang this thing on the wall like my beo4, besides against the wall it won't use any space at all on your bedside table ;-)
It's not an Iphone reminder imho but a serene reminder, not really usefull on my serene but more suitable for the beotime I think.
