I guess that posses another question (for here and the podcast perhaps) -
Because of the the speaker positions that I have to work with, is it a waste to install all four Beolab14 satellites? Is installing two at position 5 OR 6 really all I need?
I should also mention that I could install one satellite above the tv in the Centre Front Height position, but from everything I have heard/read it didn't seem that this would be a well utilised channel (just pulling the centre channel higher up) when the Harmony sound centre is so capable? Plus I only have four satellites in total to work with.
Dion.
(Assuming that you want to keep the 18’s at the back as in the drawing) - If only two 14-satelites, I’d go for the number 5’s as Surround Heights.
However, if you can easily install all four, both sets assigned as Surround Heights surely would not be bad....maybe setting the output level of the 6’ a bit lower than the 5’s.
In that case there would be more to ‘play with’ :-)
P.S. Do remember that the bas management is extremely important for a setup like this - I am sure the guys can give you some hints in the podcast.
