Hallo Miki,
I am in the thought process of doing the same as you, moving from a Eclipse to a Harmony.
But do you still use your Apple TV, or do you just use the integrated apps?
And if you do why?
Hallo Miki,
And if you do why?
Hi Guys & Gals,
Here's the link for tomorrow: https://youtu.be/lFWya7omC8w
Same time same channel, any questions go 😁
Michael
and we're live 😁
Do you have a link to that HDMI gadget you showed to manipulate which audio stream you get from netflix?
I do but only do so atm because of the many speakers in my system, if you have a 5.1 system I would just use the internal apps personally. (Iam figuring out a way to get it done through the tv though😎)
Thank you,
Just ordered a 77" GX Harmony, will try out if I see an advantages with the Apple TV else I will sell it.
Nice, congratulations! Which other speakers do you have to pair with it?
You won't be disappointed and exciting times ahead 😁
I have Beolab 5 as front and 17 as rear.
So standard 5.0 setup or maybe some would say 5.2 :D
Yea really looking forward to the size, years back I had projector, so I miss the big screen.
That'll be a magic setup and I would call that 5.2 too 😎
