BeoTalk podcast
Hi Ammier,
Congratulations with your new house!
first to start with have you tested your current wifi situation and how is it? do you happen to know what your floors/ceilings are made out of? as in wood, concreet or metal?
To start of with, if you can, wiring will always give you the best results. Having said that, I currently use the ubiquiti hd amplifi mesh and it works great here with a lot of concrete around me. I now get a heck of a lot of distance even in the hallways below me where there didn't used to be any. I used to have a massive netgear nighthawk one which had technically more range and throughput, but just got defeated by concrete with metal reinforcement in it(it's a wavelength thing) where as it works fantastic for my two last places(one was a regular house). If you live anywhere local you can dm me if you like to have mine as I now only use the ubiquiti one. So to summarise, both work great and the ubiquiti mesh is probably cheaper than the pro stuff, but it depends a bit on where you live and how it's built.
hope that helps?
Hi Razlaw,
thanks for thinking with me🙂 Both masters where on the same software and the slave speaker is on the same software too so that can't be it(I checked lol). Other than that it's gone again so I have no idea what caused it or cured it so to say. I've been testing most of the day again and doing a bunch of speaker group settings etc and it's been fine again. It still boggles my mind that, gear wise, nothing has changed really and it's fine now where it wasn't before with the same gear and no software has even been changed. It's just bizar really 😎 but thank god it's fine again now.
Hi Michael,
Thanks a lot for this, very helpful!
Its a typical Scandinavian wooden townhouse, newly built. The issue I think is that the router from the ISP just is not very good for wifi, they offered to sell another newer wifi router because I dont get a good connection on the top floor. They offered that to all the new neighbours.....
Anyway, I always hear everyone say to go the mesh network route with B&O as its more stable but then I got lost in the options Pro vs HD. I did look at the Amplify HD with 2 nodes in the shop so I am going to give that a try per your recommendation.
Unfortunately, hardwiring is going to be a pain her due layout. I currently running a short term solution of a beosound core and transmitter 1 with the 20s  and have ordered a beosound 1 for the bedroom.
Undecided on TV but thinking about the 65inch harmony for the living room, the one every dealer says is coming but its still a secret, but I dont have room for a floorstand so it depends on how the wallmount looks but I have not seen any more info on that option yet.
By the way, well done with beotalk! Great banter and good info, I thoroughly enjoy watching!
Ammier
Hi everyone,
Today/tonight we’ll be live again! The link: https://youtu.be/SjWwk0wKemc
Henrik should be back in time as he's been speaking to a bunch on Beo HQ people and went to an event to see the new Beovision Harmony last week. Let's also hope I don't roast out of my chair once again as I did today as it's about 31C here today.... For suggestions, fan pics, gear pictures email me at mikipedi4@gmail.com
We’ll go live (Sunday) at 8pm/7pm/1pm CST - Amsterdam/UK time/USA time.
We hope you can come join us live again on YouTube (link down below) tomorrow/today and otherwise I hope to see you guys in the comments!
Michael
We're live
Just checking if i can post here as it doesn’t seem to work in any other thread🙁
You can 😉
Hi everyone,
Today/tonight we’ll be live again! The link: https://youtu.be/MZB6Y1jupSg
I went to a Beovision Harmony Launch event last week and it's sooo much better in person than it is in the pictures B&O supply us with. Also, does anybody know if the Danish gouvernement built the Streur Factory in the minecraft server? 😎 Also for suggestions, fan pics, gear pictures email me at mikipedi4@gmail.com
Michael
we're live :D
