Beotalk 1200 - caller can't hear message
I have a Beotalk 1200 which has been working fine until recently.  Now, the caller can't hear the message or the tone which prompts  them to leave a message.  But, the message plays and can be heard when "listening in", and the caller can actually leave a message; its just that there is no prompt to do so!  My local dealer has never come across this problem.  Any suggestions please?
Hi George
Welcome to BeoWorld.
I'm afraid the only suggestion I can offer is to try a factory re-set. To do this enter the following code:
+ 0 1 2 3 4 +
Your dealer has probably already told you that BeoTalk1200 is now out of service life meaning that Bang & Olufsen now longer offer parts or a repair service on this model.
I hope the re-set works for you.
Good Luck.
Opman
Thanks for replying Opman; had already tried a reset with no luck.  Looks like it may remain one of life's great mysteries...
hello - are there any new ideas? Some problem with my Beotalk 1100 and I think the issue can not be a big one...
best regrads
Elmar
