I suggest that you either get the correct cable from a B&O dealer or you could make a cable, but do NOT solder on the base printed circuit module itself.
The following is a picture of the colours of the wires going into the plug in the Beocom 6000 base:-
The colours of the wires into the RJ11 plug are in the same order:-
- Pin 2 is white
- Pin 3 is green
- Pin 4 is Blue
- Pin 5 is Red
The pins of the RJ11 plug are counted from left to right with the gold pins facing you as above and pins 1 and 6 are missing in the B&O plug.
