Hey Guys i need some help...
I have got the device up and running and just need the cable which goes from the phone line to the input on the black 3way adapter.
Do i need an rj11 to BT line, 2 pin or 4 pin cable?
Simon
Simon
Your local B&O shop will be able to order your the connector. Basically the Power adapter has a telephone plug and so does the telephone to block adapter - they all plug in the black 3 way connector and then your Beotalk / Beocom plugs into the block too.
Hope this makes sense. All parts available at the B&O shop. They are the same parts as for the Beocom 4.
All you need is a POTS RJ11 4 pin "crossover" line (YGRB -> BRGY) for the wall->tridapter.
The tridapter->BT should be a straight (YGRB -> YGRB).
Available anywhere for a nickel.
P.S. Do not get hung up (😂) with the colors -it is the pattern that is important!
