beotalk 1200
Hey Guys,
I CANNOT GET MY MACHINE WORKING SINCE i REPLACED THE SMALL ADAPTOR WHICH PLUGS INTO THE TELEPHONE OUTLET IN THE WALL.
THE ONE SUPPLIED WITH THE MACHINE GOT DAMAGED WITH THE HOOVER KNOCKING AGAINST IT CONSTANTLY SO I PURCHASED A SMALLER ONE WHICH CHANGES THE SMALL PLUG SUPPLIED ON THE END OF THE MACHINES LEAD TO THE NORMAL SIZED ONE IN THE WALL. I HAVE CHECKED AND IT HAS THE 4 PINS BUT STILL WONT WORK .DOES ANYONE KNOW IS THE B&O SUPPLIED ONE SPECIAL IN ANY WAY AWAY FROM THE NORM ??
Yes, the wires are in a 'non-standard' order.  Your local B&O dealer can get you one, and they're only about a fiver..
I had the same problem with aBeotalk 1200 I bought without any leads.  As soon as I used the proper lead it was fine.
Hope this helps.
CHEERS BUDDY WILL CONTACT THEM TOMORROW
