Good day all,
I'm looking for some advice regarding what headphones I should connect to my Beosystem? I have the bed master 5500 amplifier.
Any advice and direction most welcome.
Regards,
Jonathan
Good day all,
Regards,
Jonathan
What are you expectations, your budget and do they have to be B&O headphones?
Not in a rush then???😂😂
Sorry, had online issues, unbelievable in this day and age eh?
It's more a question of what's suitable, iv heard the you need certain pre amp equipment so just want to make sure I don't get something I can't use. It doesn't have to be B&O and I'm not put off by age (so far).
If you have any personal experience I'd be very interested.
Thanks for your reply.
Jonathan
My expectations are a headphone listening experience that is better than an MP3. I know il loose something from the speakers but I want to hear the depth of my vinyl and my CDs.if I can't get that il just listen to spotify when my wife wants to watch the TV and save the good stuff for when I listen through the speakers.
I use link - comfortable, great sound, easy to drive and mine were very cheap. Better than any B&O headphones. Also have some
Thank you Peter, would both those examples fit straight to the system i have or would I need an adaptor or a peripheral?
The HD600 will plug directly in - standard small jack - the RS1 comes with the necessary adapter. The RS1 is easier to drive but the 5500 can drive either perfectly well. I do have a headphone amplifier but don't find any real need to use it.
As you want to enjoy the music in all details it's hard to hear but do not buy B&O headphones. They are very nice if you are traveling etc. but not for home use.
A few very good headphones with high detail and resolution are very cheap nowadays and are a pleasure to the ears.
AKG K702
link
AKG K701
link
AKG K712 Pro (info: This one has a +3dB bass accentuation)
link
Beyerdynamic 1990 pro
link
Beyerdynamic DT-880 pro
I'm with Peter here, if your budget stretches to it the HD600's are the way to go. They have been around for a long time now and are still considered a benchmark of performance and neutrality among audiophiles. There will be 'phones that are better but at a dis-proportionally higher price.
They are not suited to music on the move because of their sound "leakage" but for inhouse listening are among the best.
I did read something recently (I'm too lazy to try to find it again)! which said something like, "you can spend a lifetime experimenting and comparing different headphones or you can go straight to the final choice (HD600) and just enjoy the music, confident in just how good they are".
