I try again. When I try to start up the Beosystem AV 9000, I get the following error message:
SW.1.10 error 1
on the lower display panel next to the video.
Can anyone please help?
anodyne1
SW.1.10 error 1
anodyne1
Has this worked previously? Or is this the first time you set it up?
Neil
Bonjour Anodyne1,
I've read you are located in Geneva, same as me 🤒
I suppose you have already asked here: Choisy Radio-TV
They have a very good technical repair service which include all vintage B&O, TVs and HIFI, and they are not very expensive.
Good luck.
Salutations.
Hi Neil,
Set has been working fine for the 3 years I have had it. Only thing I have noticed is that sometimes the sliding curtain on startup and stopping was occasionally a bit slower, but it always worked. Only thing I can think of is that if something is not actually faulty I may have wired it up incorrectly after a recent move.
Best regards,
anodyne1.
your tv is not broken, i had the same problem with my AV9000
the masterlink cable is in the wrong socket...
