The speakers work as active by the fact that the speaker output from the 8000 is attenuated then re-amplified by the penta amp! Not really ideal!
The mod I did is simple enough -
Prepare two lengths of wire with a DIN male on the end.. This will attach to the binding post of the speakers
remove the penta amp, but watch the DIN plug and the wires that screw to the binding posts - Also note polarity at this point I think there may be a ridge on one of the wires?
Now, with the amp removed, unscrew the plastic top - don't worry, you are not pulling it apart! Feed the amp wire out of the slot in the top cover and feed it through one of the horizontal gaps toward the rear of the unit, and attach a line din socket to this. Now, feed the wire you prepared earlier IN to the same gap, but make sure it passes through the small slot on the top cover of the amp where the original speaker wire entered. Now secure the top cover back in place and you should have the new speaker wires and the DIN plug for the display. When replacing top, make sure all wires feed neatly through that little slot without getting snagged.
Now proceed to refit the amp to the speakers. Before you do - just check those long rods are screwed into the speakers properly, as sometimes you can find one or two are loose! Back to the wires, pay attention to the polarity before securing!
Plug the DIN plugs together for Penta sound or disconnect and plug into other B&O using normal speaker leads for non Penta assistance :) The whole job shouldn't take too long :)
If you wanted a clean look you could potentially route the cables back down through the amps *maybe* but this would involve pulling the amp apart so I wouldn't recomend!
Of course, as described in the other thread you could always remove the amp and displays and sell these on ebay or store them, it all depends if you think you might need the amps again!
Funnily enough, I think the speakers look far nicer without amp module at all, but only keep mine becuase my main system is a 5500, and I like the displays! Of course, if I feel like giving my 6000, 8000 or soonish to be 6000Q ( :) ) a whirl then I can connect any of them to my Pentas at any time and it only takes 5 minutes :)
andy wrote:
Step
couldnt find that thread....if i plug a standard 2 pin speaker lead from the master8000 into the speaker link of the pentalabs will it work the labs as vox`s ?
or if you could point me at the thread or just say how to run the lab`s as vox`s with dismanteling them, if its possible of course
cheers
andy
