Beosystem 7000 vs. Beocenter 9500
I think the 9500 used the Philips CDM2 transport with the TDA1541 DAC
the Beogram CD 7000 used a special version of the Philips CDM-4 transport and the TDA-1541A DAC
I have no idea which is better either technically or from a sound perspective - all I can say is that audiophiles gush enthusiastically about the radial arm Philips transports, and there is reverence for these DACs. Note the 9300 in its later versions used Philips linear tracking transports (CDM12) and bitstream DACs and these are less well regarded.
I'm sure they all sound great if you don't worry about it!
I agree fully.
I had a Ouverture system with the Beolab 2500 speakers,and found it to be..less involving.
In the same room I had CD7000 and Beomaster 7000 hooked up with Penta III`s.
I sold the Penta`s before moving,and then hooked the Beolab 2500`s to the 7000 system..
The transparency and level of detail where on totally different level than with the Ouverture,
in fact I liked the Bl2500 better than the Pentas!
Also had a shock experience when driving Revel speakers with a Beomaster 5000
-the preamp/amp section of the 5000-5500-6500-7000 series Beomasters are very,very good indeed.
I would like nothing better than to have a complete brand new 7000 system..
Good thing I have a 6500 cd and Beomaster coming my way!
In short-the source and preamp will limit what signals the speakers has to work with,
wether they be active or passive.
When it comes to design I think both the 7000 and the 9500 are excellent.
Have had them both - agree what has been said above - the 7000 sounds better but the 9500 is wonderful to use close up and almost as versatile. The Beolink 7000 works with both though the 7000 system does a few more things. I would personally have the 9500 as it is truly beautiful!
I personally also like the 4500 series a lot. Modular and with many connections on the BeoMaster that drives both labs and voxes. Controllable from the front and packed in an elegant form factor (that started with the BeoMaster 1900).
