Beosystem 6500 "No Contact"
Hi, my Beosystem 6500 displays "no contact" on the master control panel when ever I use the remote control, I have replaced the batteries in the remote but cannot get the remote to work. all items on the system work if operated manually, is there a reset or setup configuration needed as I cannot find anything in the manual about this message.
Any information would be greatfully received.
Dipstikk
Hello,
This happens sometimes with Beolink 5000 when it is set as a one-way remote.
Maybe you have the same option on the MCP.
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
There is no option on the MCP for 1 way remote.  Try switching the unit off at the mains  - wait a couple of minutes and reconnect.
Have you any other equipment (eg TVs etc) that you might have programmed by accident that may have caused the option numbers to change?
