BeoSystem 5500 Connectivity
Hi Norman,
Yes, this is possible.  Do your Penta speakers have 2 x 8 pin Powerlink sockets fitted please?  If so then please let me know as a different cable can be used, otherwise please use the cable in the link above.
Please connect the Pentas to the Beosystem 4 using one of the RJ45 Powerlink outputs, then you can link the Beomaster RCA Tape outputs to the Beosystem to share the speakers via this cable:-
Hi Steve,
I ordered the cables suggested, by you and Guy, yesterday. They've arrived this morning.
Just got to say, fantastic service....very quick turnaround, many thanks.
The Beosystem 4, beolab's 8000, 7.1 and subwoofer will arrive on Sunday so will start to connect it all up next week. The projector (Epson TW7400) and screen are all fitted and my Beosystem 5500 is in place with the Penta's. Here's hoping it all works, if not I'm sure there's plenty of help and advice available from everyone on this forum.
Regards
Norman
Hi Norman,
Thanks for your purchase, I am pleased to hear that the cables arrived quickly.  Please ask if you have any questions and I will be happy to help!
Kind regards, Steve.
