Hello all, I am looking for some advice to help me reattach a loose glass touch panel that is part of my BeoSystem 4500. The unit will by hung from the wall so it is pertinent that it is attached firmly. It looks as though some sort of double sided tape was originally used.
I am looking for some insight as far as the removal of the old adhesive and what should be used as a replacement.
Much thanks,
-Max
